Old 08-17-2025, 05:23 AM   #35
chriscpm
Originally Posted by Rotmilky View Post
Well, I replaced the ABS with a used one from a wrecked 2001 base. It had the same part number as mine (it's a 2001 S), so I figured it'd work. Installed it this morning, bled the brakes (and bled and bled and bled...there's a lot of air in the ABS to get out). Took her for a test drive and the brake pedal is back to normal. Woohoo! Nice to have normal brakes again.
Lucky thing there are a lot of used ABS units out there at a reasonable price (I paid $70). A new one from Porsche is about $3000.
So, if anyone happens across this thread in the future and has a similar issue. If a replacement master cylinder doesn't fix the brake fade, take a look at the ABS.
I know this is an old post. But I'm going down this same path. A new master cylinder didn't fix it I'm going to do the ABS pump next. Another symptom is the rear pads wore faster than the fronts after some track use.
chriscpm is offline   Reply With Quote
