Old 08-06-2025, 04:03 AM   #6
S50Sinner
Have you driven the car since the spring came out? I took mine out and fell in love with the clutch action/feel after. Heavy, but satisfying and easy to modulate.
As for the spring itself, it's an assembly with one moving part, I feel like dousing it with a liberal amount of lithium grease where the spring perches and where the pin slides shoud fix the squeak just as well if not better than a replacement. If it doesn't, then the noise is probably coming from the pedal's actual pivot point, and the spring only makes it louder because it introduces side-load on the pin, instead of being the actual source of the squeak.
And lastly, seeing as I permanently removed mine, I have a '98 spring assembly sitting around in my garage, that could probably use a new home.
S50Sinner is online now   Reply With Quote
