Old 08-05-2025, 04:40 AM   #5
maz8062
I think you could be fine, but once you put it back together, sell it on as you don't know when/if the damage will manifest itself, or not.
You should have switched the car off at the low coolant warning, topped it up with water or whatever and then driven it home. But if you were sure that the water pump was broken, got it towed home.
Good luck.
maz8062 is offline   Reply With Quote
