Old 11-20-2006, 09:44 PM   #13
clb0099
just so i explain it right the window right now is closed. The top of the window will not tuck under the rubber gasket on the hard top. When i press the switch nothing happens and if i tried to push window down manually nothing happened. It won't move at all. My question is if i am going to change the regulator or motor how do i get the window down to access the bolts i need to get to ? I am figuring it is my regulator that is burnt out. At this point I will wait for more info. I am trying to be as clear as possible . Thank you for your help
clb0099 is offline   Reply With Quote
