Old 08-01-2025, 08:01 AM   #26
piper6909
piper6909's Avatar
Originally Posted by jackfor View Post
The mechanic was not able to find the clunking sound. He said he does not have expérience with european cars. I booked another appointement with an european specialist. His shop is 1 hour and a half from me. The date is august 5, at 10:00 , thank you for the follow up.
That's too bad. Were they able to replicate the noise, at least?
How well does your e-brake hold? Have you tried going into reverse with the e-brake on, just to put load on it, but not to actually move? If it still makes the noise, you can rule out anything rotational, and concentrate on frame/suspension.
What could be happening is that the load shift going into reverse is causing some movement somewhere. It could be a loose subframe, suspension link, or even a crack in the frame.
2010 Subaru Forester
