Old 07-24-2025, 06:08 PM   #4
Burg Boxster
Originally Posted by mend123 View Post
Any help is appreciated...
'03 Boxster with headlight not working. When light switch in parking mode both headlights are dimmed. When in light on position, passenger side will not light up. When full beam on, both driver/passenger working.
Most obvious fix... change the bulb. Did that, issue not resolved. Scratching my head how the issue could still remain. Thoughts anyone?
Assuming halogen lights, right? b/c xenons use one bulb but a sliding lens so if out on low out on high.
Problem remains as me thinks still bulb and you changed incorrect bulb (3 in pod are same H7 but contrary to thought... low beam bulb is up high, high beam bulb low, and fog is inset).
Dim light you see is "city light" (194 IIRC). Anyhow, here's quick test... rotate all h7 bulbs in pod by one position... doesn't matter clockwise or anti-clockwise. Problem likely will follow to rotated position one spot.
Report back findings and we'll go from there.
Good luck
"Cool Prius!"
- Nobody
