Old 07-20-2025, 05:09 PM   #16
piper6909
piper6909's Avatar
Originally Posted by jackfor View Post
This is a video I recorded with the clunking sound.
https://1drv.ms/v/s!AmSrLd3csx6CggFAnTHv-EqsHnrN?e=qhhYSP
Do the two clicking sounds repeat, or does it just do two times and stop? Looking at the valve stem as a reference, I noticed that the video cut short just before wheel did a complete revolution after the first click started. I wanted to see if it did it again when the valve stem got to the same point where the first click happened.
I'm wondering if it's something inside the brake drum. My guess is that you probably didn't remove the rotor when you did the axle, because you wouldn't need to. But I would go there next and make sure you have no broken springs or anything loose or weird. Also look in there for rub marks between the rotating parts and stationary parts. Look for stuff like a bearing retainer bolt backing off or something. It's a shot in the dark. The other thing, if you and your friend checked to make sure nothing is hitting anything, would be the wheel bearing. But I haven't heard that kind of noise when those go bad.
2010 Subaru Forester
