Old 07-20-2025, 05:50 AM   #2
997_986
Originally Posted by DAB986 View Post
[...] it is my understanding that the early M96 engines tend to be less prone to it (as well as de-chunking) because they have a shorter stroke than the later engines and use cast aluminum pistons, which have a more robust iron coating than the forged pistons found in the later engines.
No, the reason these "low power" M96 engines do not suffer from scoring is due to the fact that their cylinder walls are thick enough and cooling sufficient. The concept was not bad at all. The problems began with ever larger displacements and thinner cylinder walls in combination with inadequate cooling.
Please do not start a "scoring thread" ;-)
997_986 is offline   Reply With Quote
