Old 07-19-2025, 10:36 AM   #5
78F350
Motorist & Coffee Drinker
78F350's Avatar
If you do a test drive, have the oil filter pulled afterward and see if there is ANY debris in it. *I assume that after replacing the RMS and IMS it's going to have fresh oil and a new filter. Any tiny pieces of metal in the filter now will indicate that the engine is contaminated and likely compromised.
It only takes a couple minutes to raise the car and remove the filter and removing the filter does not drain the rest of the oil.
