Old 07-19-2025, 05:19 AM   #1
tcoradeschi
Registered Member
Originally Posted by A 986 S View Post
The lock/unlock button detached from my Boxster's fob too. When I disassembled the fob, I found that the small metal cage that holds the button in place had deformed. After carefully bending the cage back into shape I was able to reattach the button, and it's worked just fine for me for several years.
If this fix doesn't work for you, it may be worthwhile to try to solder in a new button. That's what I had originally intended to do, and it really doesn't look like it would be that difficult. Of course, if you aren't able to fix your current fob you can always get a new one from your Porsche dealer.
Good luck getting your fob to work and do let us know if you are able to fix it.
More on my fob project here : https://rx19jones.wixsite.com/projectboxster/projectboxster5
Do you have the part number for the switch handy?
Tom Coradeschi
03 Boxster
tcoradeschi is offline   Reply With Quote
