Thread: Fuse problem
Old 07-07-2025, 05:55 PM   #3
maxbottomtime
If you only blow a fuse when the bluetooth adapter is plugged in, I think you found your culprit.
You could also measure resistance from the fuse slot to the cigarette socket, but generally if it isn't shorting to ground when not plugged in I would not suspect that wiring to be the cause.
maxbottomtime is offline   Reply With Quote
