Old 07-07-2025, 01:36 PM   #12
maxbottomtime
You could also look at the engine, see how much it shifts. Motor mount is easy to drop. 4x 15mm bolts on the bottom (nuts and studs that will likely come out together), few more on the front. Of course you need to support the engine.
You could try revving the engine (or having a friend do so) and watch for shaking/shifting.
maxbottomtime is offline   Reply With Quote
