Old 07-06-2025, 03:32 PM   #7
blue62
Originally Posted by jackfor View Post
Hello everybody.
Just bought a 2002 Boxster man 5 speed. When I'm backing up there is 2-3 clunck sound, I put it forward and the samething happen. Once on the road there is no cluncking sound. I just remove the rear stabilizing bar to rule out this, but nothing change. Anyone had the same problem? The sound seems to come from the rear of the car. Help would be very appreciated.
If your car has the original motor mount then it is shot.
The rubber center portion wears out and degrades with age.
You can't see it with a visual inspection it has to be removed to see the problem.
Or you could have an issue with the rear axles bad CV joint or axle mounting bolts coming loose.
