Old 07-04-2025, 11:08 PM   #10
Smallblock454
I would also check the oil pump for wear.
And maybe also the net / filter of the oil catchup of the oil sump. Maybe it's clogged by old sealing material or something else.
Also make shure you run the right engine oil. 0W-40 is recommended from the factory. If you run a modern 0W-20 or 0W-30 that could also cause too low oil pressure. I think - they also have 0W-8 these days.
