Old 07-04-2025, 07:28 AM   #14
maxbottomtime
Originally Posted by Marc_986 View Post
The annual inspection was delayed till today. I received a phone call this morning that it failed After all the work done, it failed on the horn So I went there and indeed, no horn. Hmmm, I did remove the front bumper, pretty sure I connected the horns again, but worth a check. They were connected. Next step, the fuse. Check location B3..... no fuse. Put a fuse in and voila, it hunks. But it doesn't stop. On to the switch, removed the airbag to confirm the rubbers of the metal plate are weak. Did a short research, read that some solved it with a few washers. So that's the easiest way. I put 4 washers in and mounted the plate back. Now the horn works as expected. Remounted the airbag and voila: PASS
Drove off with the car and at the end of the street; no gear selection It was still in 2nd gear so I guessed it would at least get me home. It did. Checked it this evening and expected the outer cable to have come loose from the gearbox (the plastic clips were broken, so I ty-rapped it). But no, the cable end popped off. I'll need to do some research on a fix. I don't want to buy new cables as I might need a different length when the V8 goes in.
Also noticed that one of the keys has a tendency to keep rotating in the ignition. Guessing the end of this ignition switch is coming close? Other key seems fine still. The remote on one of them also doesn't function, I hope it can be fixed with a new battery?
So some work to do, but at least I can legally test drive it now
Nice work!
You can buy shifter ends I believe.
For the key, it’s a pain - the fob cannot be reprogrammed. My second stopped working so trying to get it reprogrammed (and ordered a new chip). Dealer said they could do it before I bought the chip online but they are dodging my calls.
maxbottomtime is online now   Reply With Quote
