Thread: Won't start
Old 07-01-2025, 10:17 AM   #6
blue62
[QUOTE=Nallace;667773]I’m hoping someone can help. I have an 2003 Boxster S. I recently changed the engine over went in without issue but when it comes to starting it won’t fire. Turns over sounds healthy but just keeps spinning and won’t fire has anyone got any suggestions as to what the issue may be.[/Q
First thing to do is determine if the issue is due to no spark or no fuel or both?
Get a can of starting fluid spray some into the intake then crank the motor over.
If it fires or sputters then that will tell you that your getting spark but not getting fuel.
Very simple test that will give you a direction to go.
