Old 06-20-2025, 06:02 AM   #3
KevinH1990
KevinH1990's Avatar
Originally Posted by LoneWolfGal View Post
NOTE: Personally, I prefer the base model to the S. I like the base's black instrumentation, front end treatment, and massive single tailpipe. Although I don't mind the much-maligned "fried egg" headlights, I have to admit that the clear headlights give it a very clean look. But man, are they pricey!
I have a base model. While I expect the vast majority of base models had black gauges, mine was equipped with aluminum gauge faces. (Most people think they are white, but if I look closely at the right angle, I can detect a silver tone.) I have the window sticker for my car, and the aluminum gauge faces are listed as a preferred option as part of the package with a silver gear shift lever.
The fried egg headlights didn't bother me at first, but the constant bombardment of fried-egg hate on this and other forums prompted me to consider other options. I eventually found some damaged litronic headlights at a good price and with the advice from folks on this forum rehabbed them. https://986forum.com/forums/boxster-general-discussions/54697-advice-used-litronics.html
When you finish your engine rebuild, you can consider starting a "treasure hunt" for some used litronics. I had to replace the wiring harness in one of mine but compared to an engine swap that is a trivial task.
KevinH1990 is offline   Reply With Quote
