Originally Posted by 274_enduro
I think that they took the sump off when they knew something was wrong and just slapped it back together and dumped it on me
BTW, if youre racing the car, do you even need the air oil seperator? can it just be vented to atmosphere or is that going to cause some BS?
No AoS, no controlled vacuum level in the sump, no ring seal with the low tension rings in these engines...............
