Old 06-11-2025, 05:19 AM   #3
rfuerst911sc
I can't help with the metal bits but someone used WAY TOO much silicone on that sump plate . That much squeeze out on the inside can kill an engine . The silicone noodles can break off and clog the oil pickup screen . Just a thin layer is needed .
If you are going to track the car look up UAOS . It is the only AOS worth a crap . Much stronger than stock AND places the diaphragm much higher/closer to the throttle body . It allows you to run at full oil level and even higher than full . Very important on a track machine . Good luck with the car .
rfuerst911sc is offline   Reply With Quote
