Old 06-09-2025, 09:52 PM   #618
LoneWolfGal
LoneWolfGal's Avatar
Originally Posted by Newsguy View Post
I was checking into this some time ago. I discovered tow dolly’s are not recommended for the Boxster. I believe the transmission is the problem.
I was skeptical, but it turns out you and Al were correct about possible damage to the transmission using a tow dolly::
Transmission damage to your vehicle-in-tow
When towing a rear axle driven front engine vehicle on a tow dolly, the drive shaft must be disconnected to prevent transmission damage. Simply placing the transmission in neutral is not sufficient and will not prevent damage due to a lack of internal lubrication. You must disconnect the drive shaft at the rear axle and tie or wire it up. The universal joint bearing caps must be taped on to prevent loss of the bearings. If you choose to remove the drive shaft entirely, it may be necessary to cap the transmission tail shaft to prevent fluid loss and possible future damage. Consult your vehicle owner’s manual.
https://www.uhaul.com/Tips/Towing/Tow-Dolly-User-Instructions-120/
Drat! And here I'd assumed the problem was solved. Thanks to both of you. You kept me from making a dumb mistake.
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
LoneWolfGal is offline   Reply With Quote
