Old 06-01-2025, 11:20 AM   #3
nikolay5567
Thank you for the advice! It is a manual so that rules out the tiptronic issues.
I did attempt to pressurize it but it wouldn't hold pressure. I could hear air escaping somewhere around the bleeder valve but I couldn't pinpoint it with bubbles. I inspected the hoses in the area and they all seemed dry and undamaged.
Should I attempt to replace only the bleeder valve and see if that fixes the problem or should I not bother and just replace the tank entirely? Is there any way for coolant to get into the trunk if the tank is not leaking somewhere? (Coolant boiling out faster than it can drain?) The drainage tube works and isn't blocked anywhere.
Thanks again!
nikolay5567 is offline   Reply With Quote
