			I brought the car in to get a oil change and general diagnostic. I have felt some lag in performance as well. He is a Porsche mechanic so has all the testers. Just curious if anyone has had same issue and if this is an expensive fix. Some more notes that may help. I am sure engine will have to come out. If this is the case I have even though about replacing the engine with a higher performing one. I have read 996 and Audi engines can work. I could be getting ahead of myself.
 Engine noise close to oil scavange pump bank 1/3.
 Oil Leaks bank 4/6. Possibly spark plug tubes. More likely AOS vent connection top of cylinder head. Oil filler tube a bit damp Slight oil weepage close to rear crank seal an/or ims seal.
