Old 05-26-2025, 08:49 AM   #1
Frodo
Does the battery maintainer have a cigarette lighter plug as well as battery clamps? If so, why can't back-feed from the cigarette lighter or "power socket"? This way you won't have to worry about extra wires in your way while you're swapping batteries and, more importantly, you won't run the risk of the clamps slipping off while you're messing with the battery cables.
A good thought...I had been a little concerned about clamps popping off (esp the positive one).
I pulled out the bag of accessories that came with the Ctek to check. Does not have a lighter/power socket plug, but it does have this:
I can attach the red one under the nut that the red clamp is attached to in my first pic. The neg one I could probably slip over the threaded portion of the bolt over there at the top of the strut and throw another nut onto the exposed threads to hold it on.
Thanks for the suggestion
