Old 05-22-2025, 10:53 AM   #14
spinjockey
Originally Posted by boreo View Post
I'm wondering if this thread is similar to my issue. Car starts, idles, and drives with no issues. At speeds above 50mph, I get a loud howling noise from the fuel filler area. I replaced the gas cap and no difference. I am repeatedly getting the P0445 (large evap leak) code whenever I give above ~50% throttle when the fuel tank drops below 3/4 of a tank.
Not sure if the plan of attack here should be replacing the purge control valve and charcoal canister at the same time. Or do the charcoal canister first.
The charcoal canister is an easy diy repair. I suspect you have a problem with the purge control valve. Do you get a no start when filling while hot?
spinjockey is online now   Reply With Quote
