Old 05-22-2025, 09:50 AM   #15
spinjockey
Originally Posted by Rob175 View Post
I'm not sure if the noises some hear ONLY occur while filling up the tank or when driving around. Mine never "howled" but it does make a "bubbling" sound as the fuel tank fills close to full. I just always assumed it was just air bubbles trapped and being released.
IF I stop filling the fuel when the pump first clicks off the fuel gauge (in the instrument cluster) will show almost a 1/8 tank low....so I typically pump a little more in. BUT I KNOW there's a point at which too much fuel will mess with the vapor recovery system. It's a fine line.
The sound while filling is NOT the howling sound people are posting about. The bubbling is normal as the tank gets close to full. When you have howling you know you have it.
spinjockey is online now   Reply With Quote
