Thread: Loss of Coolant
Old 05-16-2025, 11:28 AM   #7
LocoDriver
OK, the mystery coolant leak saga continues. As I said in my first post, I saw no apparent place where the coolant was leaking, I filled up the coolant tank and opened the bleeder valve on the tank and, with me in the car on my QuickJack, I brought the car up to normal operating temperature at 2500 RPM with an occasional blip to 5000 RPM to bleed off any trapped air in the system. Ran it for about a minute at idle, then shut it down. When I got out of the car, there was a coolant puddle once again and the tank was empty but, again, I couldn't discern where the water was coming from.
So I decided to start taking things apart. Removed all the lines from the tank to the plastic distributing panel on the firewall in the trunk, and was ready to start the nasty task of removing the corresponding hoses in the engine compartment. My son stopped by so we decided to put the hoses back on, refill the tank again, and with him in the car on the QuickJack, proceeded to bring the car up to normal temp once again (and again with some blips). I had removed the left rear wheel to get a different angle when the leak started.
NO LEAK!!! Coolant tank remained full, car stayed a normal temp. The rain around here finally stopped, so this morning I put almost everything back together (kept bleed vale open though) and took the car out for a drive. Fully 30 minutes, normal operating temp and NO LEAK!
Luckyman: Radiators are clear of debris and car doesn't run hot.
Iceman: My car is lowered so I can only use the shorter blocks and I do place them to mate with the normal jacking blocks on the car. I do recommend the hack on YouTube to allow the QuickJack to roll much easier (https://www.youtube.com/watch?v=k0DQoEQrHmk).
Blue62: I seriously thought about this but $95 is a little much for what (I hope) would be a one-time use.
I'm stumped!
--- Tom
LocoDriver is online now   Reply With Quote
