Thread: Brake Failure
Old 05-07-2025, 02:22 PM   #2
piper6909
piper6909's Avatar
Originally Posted by Marc_986 View Post
Well, it doesn't hurt to double check indeed, but my bet is on a sticking caliper.
- Try to rotate both wheels (off the ground). If the suspect side is already dragging, you know enough
- If both rotate freely, take the car for a short drive, feel both brakes (don't touch). If one side becomes warmer than the other, take the wheel of the ground and check for a dragging brake again. But typically if one side becomes hot while the other doesn't you have found a sticky caliper.
Also check for a bad hose. Once you find your "sticking" caliper, take the wheel off, pump the brakes a few times to build up pressure, then release them. The suspect caliper should remain stuck and prevent the rotor from spinning by hand. Then open the bleeder screw. If a bunch of fluid squirts out and the rotor can then spin, your problem is the hose. If fluid drips out, but the rotor is still stuck, then you have a bad caliper. Good luck.
piper6909 is online now   Reply With Quote
