Old 05-07-2025, 09:40 AM   #583
JFP in PA
Originally Posted by LoneWolfGal View Post
Okay, I'm confused now. I understand that Loctite on flywheels and pressure plate bolts is advisable, but what about using ARP lubricant and/or blue Loctite on cam caps and camshaft cover bolts, which I will be dealing with right away, and on sump cover bolts later?
As I noted previously, a dab of blue Loctite on the treads of both the flywheel and pressure plate bolts is advised, plus an application of the ARP lubricant on just the underside of the flywheel bolt heads. I would also use a dab (don't go nuts here) of the ARP on the cam shaft cap bolts. As for both the cam cover and sump cover, a small dab of the ARP is fine, again don't over apply it; I would not use any thread locker on either of these because the bolts are rather small and the use of a thread locker could lead to bolt breakage if furhter maintence is required down the road. This is exactly how we reassemble customer's engines, and we have not had any issues as the result of these practices.
