Old 05-07-2025, 09:05 AM   #580
JFP in PA
ALLDATA said use assembly Lube on Subaru head bolts? I don't think so. Perhaps you read it wrong. Oil, yes. Assembly Lube? I highly doubt it. If so, then I'd suggest you call them and tell them to update their manuals, because Subaru says to use engine oil.
This whole discussion started when you said I was wrong for telling LoneWolfGal not to use the lube you recommend on flywheel and pressure plate bolts because they need Loctite, and now you're saying you never suggested using both? We'll let the posts speak for themselves.
We both agreed that it's good to use it on the head of the bolt, but the discussion stemmed around the threads and them binding up, which you literally said you put a dab on the threads. Again, go back and read the posts. That is, until now, after I remided you that Loctite said not to use any lubricants.
ALLDATA says "suitable lubricating oil", which is EXACTLY what ARP assembly lube is.
From my post, which you here totally misrepresent, "You definitely want a dot of blue Loctite on the threads of both the pressure plate and flywheel bolts, but a coating of this product underneath the heads of the flywheel bolts makes cranking them to their final +90 degrees after torquing one heck of a lot easier....." Nowhere in this post do I even remotely suggest using mixing or using both on the same surfaces.
"Nam ipsa loquitur" to use a long standing legal maxim...............
