Old 05-07-2025, 08:33 AM   #579
piper6909
piper6909's Avatar
I saw it on ALLDATA.
I have never used Loctite on head bolts or studs, and never used or suggested anyone use both lubricant and Loctite on ANY fasteners; but have used thread sealant (alone) when they penetrate the water jacket.
ALLDATA said use assembly Lube on Subaru head bolts? I don't think so. Perhaps you read it wrong. Oil, yes. Assembly Lube? I highly doubt it. If so, then I'd suggest you call them and tell them to update their manuals, because Subaru says to use engine oil.
This whole discussion started when you said I was wrong for telling LoneWolfGal not to use the lube you recommend on flywheel and pressure plate bolts because they need Loctite, and now you're saying you never suggested using both? We'll let the posts speak for themselves.
We both agreed that it's good to use it on the head of the bolt, but the discussion stemmed around the threads and them binding up, which you literally said you put a dab on the threads. Again, go back and read the posts. That is, until now, after I remided you that Loctite said not to use any lubricants.
