Old 05-06-2025, 05:14 PM   #5
S50Sinner
Arc-welding shouldn't transfer that much heat to the head if you just weld one tack at a time. You can get a spot-weld with decent penetration and cause no damage, as long as you let it cool down between welds. Don't go all the way around in one go, and you'll be fine.
Higher amperage should work better, as the faster you melt them, the less heat will pass through to the head.
S50Sinner is online now   Reply With Quote
