Old 05-06-2025, 09:37 AM   #11
piper6909
piper6909's Avatar
The ARP lube is used on a wide variety of fasteners, like head bolts/studs, crank carrier bolts, etc. to get optimum torque readings and clamping loads. If you go to the ARP website, they have a very interesting "white paper" comparing clamping loads, and actual vs indicated torque readings both with and without the use of fastener lubricants.
When the Porsche engineers specified a certain torque, was that with or without ARP lube? If ARP makes such a big difference, will you get the actual clamping force the engineers intended or, since ARP makes it easier, more clamping force than intended? Just a thought.
Yes, you want a little Lube on the bolts so they don't bind and "creak" when you torque them down, because if they do you won't get the true torque and less clamping force than intended. Would using ARP have the opposite?
I noticed that the label says it's "specifically designed for ARP fastener preload specs."
