Originally Posted by piper6909
True, but it seems she was talking about lubing the bolts the same way she would lube the compression tool, given she said she bought the product you suggested to lube the threads of the tool, as you suggested.
Now, putting a dab of assembly lube on the inside head of the bolt where it contacts the flywheel and the pressure plate,is definitely a good idea for proper torqueing. But you certainly do not want that on the threads.
The ARP lube is used on a wide variety of fasteners, like head bolts/studs, crank carrier bolts, etc. to get optimum torque readings and clamping loads. If you go to the ARP website, they have a very interesting "white paper" comparing clamping loads, and actual vs indicated torque readings both with and without the use of fastener lubricants.
