Old 05-06-2025, 03:06 AM   #2
piper6909
piper6909's Avatar
Originally Posted by LoneWolfGal View Post
I picked up some of this stuff, on JFP's recommendation: "ARP 100-9909 Ultra Torque Assembly Lubricant - 1.69 oz. Fluid Squeeze Tube." $13.99 at Amazon. I will of course use it on the compression tool, but it seems to me most fasteners used in the engine would benefit from it. What about flywheel and pressure plate* bolts? Cam cover and sump cover? Cam caps?
*By the way, I've decided to replace the pressure plate along with the clutch disc and throwout bearing. I had intended to replace only the disc and bearing, but I've come around to the idea that I'd be crazy not to put in a new pressure plate while I'm at it.
Definitely not the pressure plate and flywheel bolts. If it's like most other cars, you'll want loctite or some other thread locker for those bolts. Assembly lube would have the opposite effect.
piper6909 is online now   Reply With Quote
