Old 05-03-2025, 07:35 AM   #556
cooler
We have had excellent results with the factory parts and generally only use them unless the customer request something special, only then if we think their choice is not going to lead to problems.
We replace the disc, pressure plate, all bolts, throw out bearing, and pilot bearing in a standard replacement. The flywheel only gets replaced if it is either severely heat checked or fails the factory "twist test" for the dual mass assembly.
Hello, I am really hoping someone could measure the distance from the engine/bellhousing flange to the flywheel friction surface on the M96 (I believe this measurement is the same on all variants) Should be about 50mm. be accurate to the mm.
cooler is offline   Reply With Quote
