Old 05-03-2025, 07:02 AM   #555
JFP in PA
We have had excellent results with the factory parts and generally only use them unless the customer request something special, only then if we think their choice is not going to lead to problems.
We replace the disc, pressure plate, all bolts, throw out bearing, and pilot bearing in a standard replacement. The flywheel only gets replaced if it is either severely heat checked or fails the factory "twist test" for the dual mass assembly.
