Old 05-02-2025, 11:32 AM   #11
LoneWolfGal
LoneWolfGal's Avatar
We never reuse either pressure plate or flywheel bolts, they are not that expensive and typically under high loads in use, plus the flywheel bolts are torque to yeild (torque spec + additonal angle) which automaitcally precludes reuse.
Amazon list the threaded rod with one day delivery: https://www.amazon.com/dp/B078H6J4D3/?coliid=ISRITT0IKCK3V&colid=2HC5QQFJX9KXZ&psc=1&ref_=list_c_wl_lv_ov_lig_dp_it
uxcell M5 Fully Threaded Rod, 304 Stainless Steel, 250mm Length, 0.8mm Thread Pitch, Left Hand Threads
Appreciate the info. I ordered new bolts for the pressure plate and flywheel. I went with Accu instead of Amazon for the rod and nut, chiefly because Accu's hex nuts are stainless steel, whereas Amazon's are carbon steel.
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
LoneWolfGal is offline   Reply With Quote
