Old 04-27-2025, 09:41 AM   #516
LoneWolfGal
LoneWolfGal's Avatar
A little Sunday interlude to discuss raising the car. Problem: My supposedly low-profile floor jack isn't quite low profile enough to fit under either the front or back, a common and aggravating problem. My makeshift fix has been to run the car up on two 2x8s under each wheel. They provide enough clearance for the floor jack, but wood tends to slide on concrete, a PITA. Solution: these ramps at $27.69 per pair:
https://www.amazon.com/MAXXHAUL-50699-Capacity-Profile-2-Count/dp/B0BMQYKLYJ/
The maximum height for my four jack stands is 19.5", which raises the car high enough to work underneath without it being claustrophobically tight. That will have to do until I can get a 2-post lift:
https://www.amazon.com/APlusLift-HW-9KFL-000LB-2-Post-Floor/dp/B07F6591TR/
And then what a happy world this will be!
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
LoneWolfGal is offline   Reply With Quote
