Old 04-25-2025, 01:00 AM   #2
Boogle
Originally Posted by theiceman View Post
if there are 3-5 mm of thread that should be enough to screw a nut on ... a couple threads.. if that is the case i would DEFINITELY weld. The heat alone from welding the nut on would help too ... i drill as a last resort . cant speak to stick vs TIG , it depends what you have on hand i guess
Thanks! Yeah, they are pretty rusty, but there’s enough thread left to even screw a nut on a little bit to keep it in place.
Still worried about welding just being too hot and there being a danger of warping the head. Hoping to hear that this is not a big risk if I take it easy from someone that has been through this with an M96 engine. Have you, Iceman?
I have found quite a lot on the net of people drilling out with jigs on M96, but not much about the weld method. Wondering why.
Boogle is offline   Reply With Quote
