Old 04-24-2025, 11:41 AM   #1
theiceman
if there are 3-5 mm of thread that should be enough to screw a nut on ... a couple threads.. if that is the case i would DEFINITELY weld. The heat alone from welding the nut on would help too ... i drill as a last resort . cant speak to stick vs TIG , it depends what you have on hand i guess
theiceman is offline   Reply With Quote
