Old 04-23-2025, 09:21 PM   #495
elgyqc
elgyqc's Avatar
Originally Posted by LoneWolfGal View Post
I would be surprised if Grant hasn't already fabricated one. How about it, Grant?
Have you been spying on me? Actually, on the first engine I did I was rather naughty, I just used a tap to change the threaded hole to take a standard right-hand SAE bolt, see post #9 here,
https://986forum.com/forums/performance-technical-chat/80969-going-through-my-original-engine.html
I then thought about using a smaller bolt that would pass through the threaded hole, with nuts at both ends to accomplish the same thing.
Finally I bought a left-hand die and and some bronze rod and made a couple of tools. It was not easy and not one of my great tool making moments... I thought I had documented it somewhere but can't find it.
It is also possible to use a clamp to compress the tensioner, which I tried the first time round, but the clamp tends to slip off the tangs.
Grant
