Old 04-18-2025, 07:52 PM   #15
JZeke
bumping this one as I also have this driveline vibration under acceleration but zero vibration revving the engine warm stationary.
also have a new front mount, new clutch put in when gearbox was taken out for a rebuild, new axle mounting hardware (but old axles). Alignment done last year. Diagonal control arms and end links are new but lower controls arms old. 79k 03 S. DMF was checked out when clutch replaced, they said it was good. also get a low speed clinking/rattle from driver side rear over rough roads at very low speed which may be related.
  • transmission mounts
  • DMF
  • lower control arms
  • axles
if the vibration is only present under accel and in all gears, what’s the proper way to diagnose the fix? Of these 4 potential culprits, which is more likely to cause these symptoms?
'03 Boxster S
'23 X3 30i M Sport
'23 Cooper S
JZeke is offline   Reply With Quote
