Old 04-17-2025, 08:38 AM   #1
kmarei
Exclamation Help with vacuum line
I am in the process of replacing all the vacuum lines
while trying to clean the throttle body, i broke 2 of them
so figured if i am fixing 2, might as well do the rest
all are done now except the one behind the vacuum reservoir
its the one that goes from the changeover valve to the vacuum line junction next to reservoir
what i need to do is to plug a hose from E to G
but can't get access to E
is there anyway to get to this WITHOUT removing the alternator OR intake manifold?
i tried removing the secondary air pump and tried to go in through the gap between the intake manifold
i can just barely touch it, but the existing U shaped hose is stuck on tight
and i can't get a good enough grip on it to pull it out, to plug in the new hose.
i thought maybe angled pliers to hold the old hose and pull it out?
kmarei is offline   Reply With Quote
