Old 04-16-2025, 10:38 AM   #20
strtnz
Looks like the sensors may send a different signal entirely. It could be your 2000 has a passive sensor and the 2002 has an active sensor. One sends A/C current in a sine wave while the latter sends a digital square wave. If that's the case, you'll get an error code regardless of the tooth count on the ring. So, you're stuck with having to get the correct sensor.
Here's a helpful video:
https://www.youtube.com/watch?v=LC3jCyHjWqo&t=155s
Perfect. Then I can test each sensor's output voltage and if they're in the same range I'll have a go at splicing, if they're in different ranges I'll know I need to buy an original sensor.
strtnz is offline   Reply With Quote
