Old 04-15-2025, 03:28 AM   #13
Cunningr
Cunningr's Avatar
I just had a major service done my car has 57000 Km it had the IMS kit installed when I bought, however the mechanic did recommend the RMS be addressed mostly because I had developed oil leaks. I had him do the clutch, as the previous owner did not. In my case I did have some seepage on the RMS seal.
But after reader many post on a car with lots of miles and the IMS hasn't failed probably not going to as the fell rate was very small percentage and the failure occurred early on, however as mentioned if your keeping the car and make you sleep better then get it done will you have the clutch installed will save on labor cost.
