Old 04-11-2025, 01:25 PM   #14
78F350
Motorist & Coffee Drinker
78F350's Avatar
Now I'm figuring out which rail and injectors I want to use. Probably the set from a 2.7L and not the 3.2L. Is there an advantage to the S model injectors? ...probably not on a base model engine.
Meanwhile here's the Tech article on Pelican: https://www.pelicanparts.com/techarticles/Boxster_Tech/25-FUEL-Injectors/25-FUEL-Injectors.htm?srsltid=AfmBOoqsf5WTIT6276l0s4mPqZxk E1ab6YvjctBQ1rOpPa1EP3oAolJJ Note that the instructions are with the engine in the car, but NOT the pictures.
Base vs S:
