Old 04-10-2025, 01:08 PM   #20
Petecomplete
Originally Posted by Rob175 View Post
Wouldn't water or coolant in the oil cause the oil to look "foamy" or "milky"?
The posted picture looks somewhat translucent and really not bad at all....unless I'm missing something....which is possible (lol)
It would, when there is enough of it. But if you have slight condensation and it hasn't mixed into all the oil you can get these "layers". I've had a couple of outboard engines with both slight and massive water intrusion in the underwater housing/gear oil. with a lot of water its milkshake look if the engine has been run a lot and properly mixed. If its just slight, and the engine hasnt been run a lot, you can see seperation layers. Some clear oil, some more milky.
I did find moisture/droplets in the oil filler cap.
But the oil report will tell. i'm starting to be optimistic.
Petecomplete is offline   Reply With Quote
