					Originally Posted by JFP in PA  Yes, these boots can and do leak.  If yours is leaking, yes you have to remove the AoS to get a it, and I would HIGHLY recommend replacing the AoS along with the boot, and ONLY USE THE FACTORY AoS, NEVER AN AFTERMARKET UNIT. |
Bump.
Agreed 100%.  I had mine replaced by a URO and the bellow cracked.  So much for a replacement
Mine is in the shop this week to have it replaced.
Edit: For context, I had my AOS replaced in 2019. Since 2022, it's mostly seen DE days with my local PCA so it gets driven hard.
