Originally Posted by djomlas
those come apart as i remember....u put the bottom part in, and then the cap after it. correct me if im wrong
Yes, you're right.
Blink, put the base in first, then slide the cap right into it. They're made so that you can't put them in as an assembly. The stem on the cap expands the base so that they can't pull out. Try it again dude, you're almost there.
