Old 04-02-2025, 07:38 AM   #2
Cunningr
Cunningr's Avatar
Rear spoiler is both automatic and manual, there is a switch near where the relays and fusers are located to manually raise it. Normal operation it will be down until around 70 MPH. Best suggestion I have is try using tee manual button to see if you can lower it manually. Most likely fuse or relay issue. Definitely not tied to convertible top.
